Arctic Blast coming to Northeast next week
Heavy rain here expected to get 1-2 inches, so will know tomorrow how close the forecast was. Tapering off now.
We had the rain and some flooding, was 51 at 3pm now 27 and windy.
Had one fire today let it go out 5 hrs ago, time to fire it up now
Sunday we had light freezing rain,thin coat of ice in the morning,light rain in afternoon/evening,temps upper 30's.Started snowing late Tuesday night,by early morning Wednesday 4 to 8 inches on the ground (6.4" here).Temps upper 20's,slowly falling with 40MPH gusts & near zero visibility.Travel not advised in rural areas.
Right now its 4 degrees w/ -19 windchill.May hit 8 for the high today if we're lucky.-8 tommorow morning,gradually warming up for the weekend. Low-mid 30's expected then.
We got some strong gusting last night. Some big trees came down in town knocking out power to a few areas and also blocking the road that is my primary route to work. We heard a huge crash in the back yard around 6:30am and it turns out our giant white pine dropped a couple large branches (5-6"). Looks like about 2-3 stove loads once I cut it up.
Holy $#*&#&^ Right now its absolutely pouring rain outside, coming down horizontally. More big branches coming down. It looks like TS Sandy conditions outside!
About the only good thing from the rain we received is it cleared most of the ice from our driveway, it also pushed the brook out over the banks, it should be worse tomorrow.
Starting to snow at the moment.
  • [Hearth.com] Arctic Blast coming to Northeast next week
31 outside with snow and wind right now. They are calling for 3 inches tonight.
Things are getting worse on the Brook, up above us they brought in an excavator by the S curve, they brought another excavator on our property by the Brook to remove ice.
That looks like a mess, Stay safe.
Last time we had heavy,heavy rains it blew out 7 bridges in our town, two of the bridges the brook took out.
I just checked my area lake has rose 10 feet since yesterday evening that is a big rise for the lake here. It only has 6 feet to get to summer pool.
We need the water, just not all at once. Just spoke with the town supervisor, I told him if he needs to get back in the woods (to check the brook)just give me a call.
I think they might pull some ice out from the banks of the brook up on the S curves, by the bridge in the picture they have the excavator there just in case they need it.
we had pouring rain with high winds, clear and sunny 60 degrees, then slightly overcast with bitter cold gust, and now its snowing...all in 1 day. is crazy times.
If they put a Cat on your property is it ours? ;) The town positioned two excavators in different locations (one on our property) in case they have some ice jams. The two bridges they put them by both were taken out in the fall of 2005 by heavy rains/beaver huts that came down through.
Pic 6746 is up the brook where some ice is pushed to the sides,6744 is across the road from our property that the ice is building up, 6743 is the Cat.
Sheesh. Last time I looked at the forecast there was a chance of flurries for this afternoon. I went out to pick up and stack some wood I had split. Flurries began and before I knew it, the quad, the wood and I were covered in a half inch of snow. Wind hasn't really let up since that nasty front blew through a couple days ago. Tonight it's supposed to go low double digits with gusts to 30 mph. Then, finally, some decent wood-gettin' weather for several days.
Got a killer load in the stove, dropped the bypass and she has just taken wing... :)
Looks like that clipper has got here.
With the rain stopping along with the colder weather the Brook has calmed down, still some ice build up on the other side of the road.
Reactions: ScotO and corey21
Got 4 inches of snow on the ground at my house from this last storm.
Reactions: ScotO
Send that up hear, the snow we have is hard like cement or like Sav called it today, rock snow.
It is still snowing lightly outside the last time i looked. The bad part is that my seasoned wood got covered out on my porch we have had blowing snow. Been fighting with damp wood with frozen water on it.
Do you have a tarp?
Do you have a tarp?
No i just use an old pool cover to put over my stacks. Just did not cover the wood on the porch before this snow that was my bad...
I could use a week with no snow.
It should be fine if it was seasoned for a year, a few days inside before you burn it should do the trick. All our wood is stacked outside with the tops covered, it's never really been a problem if it's been seasoned a year, oak takes longer.
Reactions: corey21
Yeah it does fine if it has been inside a few hours i can get to 650 stove top so it is just from the snow.
It looks like this next storm will hit the Eastern New England states pretty good if it comes together, they're calling for 6-12 in our area, I'm sure that will change.
From AccuWeather:
When these two storms join forces, a fierce blizzard is expected to unfold across eastern New England from Portland to Boston to Providence.
Blizzard conditions will develop in this corridor Friday afternoon, leading to a nightmare for the evening commute. The worst of the blizzard will then howl Friday night.
