Hello— I’m wondering if anyone knows an estimate of the volume of a cord when stacked for drying (3x3). I understand the answer will depend on split size but I don’t need exact precision just a ballpark if anyone has one.
Yea I get that but it all assumes the wood is stacked compactly. Sorry if I wasn't clear.There is no variation. A cord is 128 cuft.. or 4x4x8=128 or 2x 4x16=128 or 1.5x4x21.5= 129 cuft.. A cord is a standard volume of wood .. no matter how its stacked or cut to length.. volume of area.. same thing for me.. I can tell you a cord in log lenth.. WxLxH= volume of area
If it really matters break a stack down and straight stack it and compare the volume
25% is a real good guess.I'd think that stacking like that you'd gain 25% pretty easily...but really it all varies on the person stacking, so...it depends
My understanding is the point of stacking a pile like the one on the right is to significantly increase the amount of airflow through the pile, so I was thinking it would have to follow that there's significantly less wood.
I've burned out in the country but I'm now burning on a small city lot for the first time. I'm just starting to build a stock of wood and don't have much space, so >10% difference would be significant to me.
Initially, I thought "That's gotta be 10% at least," but 25% is big. Reasons to cross-stack for me would be if I was under the gun to get some wood dry as quickly as possible, or if I had room for only two years' worth so couldn't let Oak go for three years, or to get better air movement into stacks that are three rows wide on the stack bases.25% is a real good guess.
I just measured one stack-- one 9 cubic foot criss cross stack (18x18x48) was 6.83 cubic feet when stacked straight, which comes out to a 0.758:1 ratio.
As long as your stack has some reasonable air flow, you aren't going to gain any drying speed by cross stacking. The limiting factor is internal wood diffusion and tiny change you have in your surface boundary condition from stacking type won't matter much there.
In other words, stack normally with a top cover only, if you get much rain and your wood will dry.
