For sure. I've been burning some three-year Red Oak recently and it is rockin'!Yep wet wood does not burn. Get that oak seasoned for 24-36 months and it will be better probably.
Try an angle grinder with a cutting wheel to cut the liner. Like a warm knife through butter (almost), and no distortion. Also used it to remove parts of the cast iron damper to make way for the liner.Got the XTD out last night, but cutting the flex pipe for the taller insert is a major pain with dull metal scissors, getting a pair of real cutters after mangling the pipe and a lot of cussing. Hope to finish the install this weekend.
I do have my fair share of concerns that the reducer does not attach to the top of the insert, I am being really careful with how much I cut of the flex pipe so that it will have enough force to push down on the adapter to keep it seated (in theory).
The stove looks nice, looks well built from the look over I gave it last night. Not to crazy about the door latch, just a piece of metal welded to the handle, hope it holds up.
I am considering replacing the 3 speed switch with a variable speed so that I can slow down the fan more on my 52. I read back through this thread and saw where others considered it and I am wondering if anyone actually did so. If so what were the results?
ceiling fan rheostat
I am on my 3rd season with my cats, they still look good. I think you are running the stove way to hot with the controls open that much, do you have a cat temperature probe? I bet you are cooking your cats, but at the same time you are running hot enough to keep the glass clean![]()
Dry wood helps A LOT with keeping the glass clean. I'm on year three of my cats...I dint have the same stove you do and I have Condar cats.Just got done reading this thread on the 52 bay, great info. I have had a 52 since 2009 and have had many of the same issues. There are things that I love about the stove and things that I hate. I haven't closed off my ash door like some have because I keep my fire burning continuous and like to just sift the ashes into the ash bin before I reload each morning. I am going through my stove now and am going to try to seal the ash door better so that less air is fed through it. I have also experienced the warped flame shield and even a crack in the damper housing. I added extra fire bricks to the factory location so that the brick goes up to the top of the stove with hopes of holding heat longer and preventing heat from leaving the back of the firebox. All in all, the stove has performed fair for the price. I burn it steady from October through March, and clean the Cats about three times per year. My wood supply is not always top notch and this has lead to some of my problems with the stove. I have to add extra air to keep the subpar wood burning and have let it get too hot once the moisture comes out of the wood. I only get about 3 years out of my cats due to this. I'm making good ground on getting ahead of my wood supply this winter so this shouldn't be an issue in the future. I am not experiencing the glass issues that others are, I can keep my front glass 75% clean most of the time, I feel that this is due to keeping the primary air controls at least 25% open all of the time. keeping logs as far away from the glass as possible helps as well. How many years are you guys getting out of your cats? I find it hard to believe that anyone is getting the 10 years that fircat claims is possible.
I do have a temperature probe that was given to me by my dealer but I don't think that it is getting close enough to the cats to give me an accurate reading. My probe never goes over 1600 and is usually around 1000. The end of the probe is about 3/4" from the front of the cat. I'm going to order the longer one mentioned earlier in this thread.
Is this an Insert install or Free Standing?
This above..also what are the ceiling heights in the house?First step would be to install a block off plate and insulate that fireplace.
