I just received my auberins thermometer today with 4" 1/8" probe. My question is: how heigh above my stove top should I install it into the stovepipe? I was thinking 18".
For me, I want one with alarm because there has been times the stove damper has been left fully open for too long and the stovepipe has gotten quite hot.
Mine started throwing error codes already (only had for 2 days). Contacted auberins and they've already got another one on the way. I think they are pretty delicate but very cool. Oh, and northernontario, I agree. I throttle mine back at 900 (on a reload) and higher on a new fire.
Then of course the nerd in me asks why we can't find one of these that will hook to wifi and send an email out. :D
That's a pretty slick little device, there's only one thing I'd like that's a little different, the ability to monitor or switch between two temperature probes. It would be great to place the eyelet one for monitoring the stove top temps, and then the probe to monitor flue temps, one place to go for all your temps!
Yes this is exactly the model that I've been drooling and drooling about but somehow I suspect after the novelty of all the graphing and testing and tracking wore off I'd go back to basically just using it as a high/low alarm which the Omega DP7000 does for a fraction of the cost. Still this would be so super sweet and would probably allow me to use the stove while I was at work but $500 is absolutely insane. The problem with the DP7000 though is that it is only going to go up to 999F and while that would probably work very well for stovetop surface temps I don't think it would work well for a flue install? Anyway if money were no object I'd opt for this in a split second.http://www.omega.com/ppt/pptsc.asp?ref=ISD-TC&Nav=dasc01
If you have a spare $500 sitting around you can have that, someone needs to do a kickstarter for something like this in the $100 range.
Turbocruiser, could you take a picture of your setup of the Omega DP7000. Please explain where and how you set that up.
