Nope, never tried the Leveraxe. There was a test model floating around AS a few years back and a loooong discussion to go with it.
If most of your wood is shorter rounds of birch (preferably frozen), then it might suit you. Otherwise, it's too specialized for my eastern hardwoods and I've categorized it as expensive gimmickry.
Brother sent me the link via nbcnews on facebook a few days ago.Asked me what I thought of it.Told him "I thought it was no more than a yuppie axe,an overpriced fancy gimmick."
Noticed on the company video that it looks like straight grained pine or birch that is being split.Then brother said "Who burns PINE?" He mentioned "how he'd burn pine in the firepit or when camping,but NOT in up the chimney in his open fireplace...."
So...... I had to educate him on the 'pine is dangerous & no good for indoor burning etc myth...." Explained that most everyone living on the pacific coast/western US,northern parts of US like Maine etc & northern Europe have little or no hardwoods,have been using softwoods for fuel & building material for thousands of years etc etc...." Think I got through,not sure though....
Looks easy on medium sized straight grained knot free softwoods such as white pine or spruce.Would be interesting to see how it behaves in twisted,gnarly knotty White Oak,Mulberry,Honey Locust or Elm/Apple stumps....That stuff just laughs at my X27,have to use the sledge/twisted wedge or break out the big saw for that brutal stuff........"
As of last Wednesday that Vipukirves ax was $277.08 with shipping to US addresses.....NO WAY!
There will be no twist in the wrists, because the splitting technique is such, that you must hold the handle as gently as possible in your hands to allow the rotation.I saw it pointed out somewhere that the torque at the end would be very painful after a short while. Notice what the axe does when it stops and see how it twists your wrists.
HOLY CRAP...and I thought my Tennis Elbow was bad NOW.![]()
Also, it looks like ya have to move in a clock-wise circle only.
$277 is a payment towards a hydraulic splitter no?
It can also be done this easy.All I can say is I only have one badly-damaged arm, and my Fiskars does me quite nicely. I don't know if I could take the torquing.
When splitting firewood with the Vipukirves/Leveraxe it really does not make any difference whether the wood is frozen or in summer temperature. This is because of the nearly non existent friction . The blade of the Leveraxe penetrates into the wood on an optimum strike only 5 millimetres, less than a quarter of an inch.
The conventional axe and maul must go all the way through the block and struggle it's way against the friction. In the winter the moist in the wood is frozen that makes the wood slippery. That is why the splitting is easier in the winter with the axes based to wedge.
The Leveraxe splitting technique multiplies the splitting force many times bigger because of leverage. Momentary splitting force can be over 15 tons.
Most of the splitting power with the conventional axes and mauls vanishes to the friction.
Based to the feed back from all over the world, the hard wood is not any more a problem, when splitting with the Leveraxe.
Here are some videos to make it easier to understand.
It has nothing to do with the axe. I was commenting on the tree species, phase of water in the wood, and length of round to be split. Fact--some tree species split much easier than others. Fact--in some tree species, the added pressure of frozen water (solid water is larger in volume than liquid water) in the wood can make splitting easier. Also, some species split better after seasoning and some split easier when green. The videos are deceptive unless all testing conditions are disclosed (truthfully) and by knowledgeable test designers.
Force doesn't change due to the shape of the head. Force per unit area contacting the wood on impact (Pressure) does. Impact force is another story.
Because of its much lesser mass, much more velocity (human effort) is required than splitting axe alternatives. I thought the feedback "from all over the world" included reviews form Arboristsite.com?
Please disclose all of your connections, direct and indirect, to this product.
Just to point out some generalities (yes, I know there are exceptions)
Over the pond (where this was born):
A: it is common for them to cut their wood shorter (small stoves)
B: It is common for them to split smaller (small stoves)
C: Their firewood is mostly of softer varieties
D: There is very little old growth or large trees that are getting used for firewood over there.
All of these things can add up to a hugely different splitting experience than us 'Mericans are used to. That doesn't make it a good or bad tool. It just must be taken into account for using the right tool for the right job. Beating the heck out of some nasty elm ain't this tools place. But snapping sticks off of some straight grained softwoods it might just be the cats meow.
This double video shows the difference. Count the number of strikes. Compare the work load.
http://youtubedoubler.com/?video1=http://www.youtube.com/watch?v=9ol57Y57-mw&start1=0&video2=http://www.youtube.com/watch?v=UJt-UR9f_a4&feature=channel&list=UL&start2&authorName=meahwahwah
I am not sure what that comparison is supposed to show. The Fiskars guy is using (trying to bust the log in half then quarters), while the vip is peeling off of the edges AND with what appears to be a shorter round. For every video that you put up, I can post one single pic that proves my point of the proper tool for the proper job and that the VIP is not the answer for all:
Split THAT with ANY hand held tool. I dare you.
I am not, repeat, NOT trying to take anything away from that tool. I was part of the discussion on the original threads about this tool when it was being tested by many people over here. The consensus was pretty clear. Straight grained, easy splitting stuff was where this tool shined. Difficult, gnarly, twisted grain stuff...not so much.
I only wonder why you want to fight against the strongest resistance what you can find in the tree, if there is the way how to beat it more easy.I think what people are saying is that this tool comes at an incredibly high premium, but really doesn't do anything that a normal axe can't. Of course it's easier to split off the edges, that's where there's the least resistance, so the above video proves nothing
If this axe could bust a big gnarly piece in half easily, people might be more interested. But as it is, the price doesn't warrant the benefits
