Thank you for these very valuable insights. I wrongly assumed the polution numbers are similar, and I definetly missed the improved safety distance of the F205/F200. At our place, the stove will be against a stone wall which has mortar finish, so I assume is not considered flamable, but I appreciate the convection plate and the smaller safety distance.
Regarding the
outside air intake (
external air) topic, I have mixed feelings.
We bought the house 4 years ago and there was a big wood stove in the living room which showed signs of regular usage by the previous owner. We thought the old stove was too big and did not like it and when we renovated the house, I sold it for next to nothing just to get rid of it.
Fast forward to today, I asked two dealers for stove quotes including installation. The first dealer refused to quote stating that I need to get first an external air intake sorted out since this is a must have according to current regulation. The second dealer said that the chimney sweep might/should accept the new installation without external air intake because there was stove here before. Worst case he will drill one for EUR 800 if the sweep insists.
I would like to do it right, but it is not easy due to the wall thickness of 60 cm (24”) and the perpendicular wall where I could drill the 10cm/4” hole is 2.5m (9 ft. ) away from the stove.
Also, since the previous owner was using a large wood stove in this exact place with the same windows and roof insulation, I am thinking that it is safe to say this will work.
Of course, I would also like it to be a safe install, and from what I am reading online, the outside air requirement is to prevent the smoke coming back to a lower pressure in the room than outside, and this is a serious safety hazard. But many people are at the opinion that the outside air is a must only for new houses with excellent insulation. I would not consider our house leaky, but it is also not insulated to today’s standards. The windows are decent and double glazed, but 20 years old.
I would like to look into the potential to install a tube in the chimney for the outside air intake. The chimney currently has 2 tubes, one for the smoke exhaust and one for the kitchen extractor.
I am thinking that if there is room in the chimney for a 3rd tube and installing it will not going to cost me an arm and a leg, this might be the best solution. Safe and efficient, potentially very costly.
The other option is to just install the new stove as the 2nd dealer recommended and hope that the chimney sweep will not object to it and make me drill a hole. The hole 2.5m away does not sound efficient. The stove would have to pull cold air into and across the room to get his air needs. I will probably lose a lot of efficiency? As you said, getting the external air as close as possible would be the best, but the wife would probably not like a pipe inside the living room for the exterior air intake. Huhh
