Anyone grow garlic??? Looking for advise, ideas on how to begin. I know it's a bulb but I'm wondering if you plant it in rows, and how far apart ect...
I have a small raised bed I was going to use for onions and garlic
Order garlic in august.  Hardnecks shorter shelf life and taste better, softnecks are the braids that keep longer but much milder.  Elephant garlic not garlic but leek, but works same but  with little flavor so I've never bothered.
Plant on columbus day.   Choose largest  cloves as  size directly correlates to bulbs.
In raised bed 4 cloves/square foot.  If doing row in bed, every 4" then stagger next row.
Mulch heavy w/straw to overwinter.   Pull mulch back as weather warms.
If you do hardneck, they will develop flower heads called scapes a bit before harvest.   Cut them off to direct energy to bulbs.  Saute them in butter and enjoy.
Usually early julyish here, tops will start to yellow and droop.   Harvest when about a 3rd of it browns.   Do not yank them out.   Use fork and gently lift them out without damaging skins.
Eat any with poor/damaged skins fresh.  Dry and cure rest.    Save biggest bulbs for replant.
Crack bulbs open and select largest and prettiest.   Replant and start again on columbus day.    Hardneck garlic is a microclimate influenced plant that adapts to its area, so after few years, your garlic will have unique taste only found in your garden.
Note:  the little seeds in the scapes are called bulbules.   If you want a lot of garlic faster, you can let the scapes flower and harvest and plant them in fall.    They grow small though, so it would be many years of replanting  bigger bulbs before you get good size, but sometimes bulbules are only way to get rare varieties that produce fewer cloves to share.
hth,
tom
