Operator Randal just hung up on me. Apparently these units have not been tested for their efficacy against radioactive sea monkeys.
I'm going to Hell.
I'm going to Hell.
I picked one up for about $320 or so...here is the link from where I purchased:
http://www.iaqsource.com/product.php?product=171090
Like I said earlier, I had to purchase one of these units in order to get the ok from the building inspector...I have mixed feelings on it, but will have to wait and see once it is up and running.
its reading 47% whereas the reading outside is closer to 85%.
In a house with an airsealed basement and attic, Central AC is cheap to run (outside AZ and FL), and if the basement is damp, just provide some AC supply, or put a return down there, and it will require less energy than a dehumidifer.![]()
It's not that simple. The dewpoint is often higher during the day than at night, indicating that the air contains more humidity. The temperature dependence of RH obscures this fact, and is the source of much confusion.
Great calculator ,super easy to figure. It shows im on the right track for my area by ventilating during the dayI prefer: http://www.dpcalc.org/
The weather channel gives the same dew point for the entire day,53 for a range of RH from 50-60 daytime to 80-90s at night. I still tend to think its hard to benefit from drawing in 90% humidity air overnight. During the day temps are in the 80s and at night its about 60deg.
According to the scale at dpcalc.org there is a big difference.You are right that there's no benefit to bringing in 60F/90% air at night, but it's the exact same as bringing in 80F/45% air in daytime, so one can't be bad and the other good, they are likely both a bad idea.
TE
No, they both contain almost the exact same quantity of water, that's why using DP is so much better for this purpose.80 Deg air at Rh45 is much drier than 60 Deg at 90Rh according to the chart
