SmokeyTheBear said:What was burned in the flue you ran the liner up before you got your stove?
SmokeyTheBear said:Likely some of that piddle poor stuff from across one of the great ponds.
Was the damage all below the block off plate?
goathead said:SmokeyTheBear said:Likely some of that piddle poor stuff from across one of the great ponds.
That's what I'm thinking. All the damage was from the stove up about 12 feet. The block off plate was still sealed at the top of the flu so I didn't have any water leakage. I'm at a loss.
Was able to get in touch with the installer and they are going to check into the warranty but apparently they say it's only covered if you're having it cleaned professionally every year and have the receipts for it. So I'm guessing that since I clean it myself that I'm going to be SOL on the warranty.
BrotherBart said:This is where they get ya.
"4) The Forever Flexâ„¢ lining system must be cleaned and inspected on an annual basis by an experienced chimney professional (i.e., at intervals of no more than 18 months each, commencing from the date of purchase), who must fill out and date the appropriate section on this warranty card upon completion of such yearly maintenance. Receipts verifying the annual maintenance was performed must also be retained."
I have always said that liner warranties aren't worth the paper they are printed on.
Delta-T said:wow, thats the first time i've seen something like that on a liner....the power of carbonic acid (and other)..sure it wasn't aluminum? There are literally hundreds of types of steel, some 60% of them didn't even exist a few decades ago....yeah for materials engineering. My fav is Lustra....super high chrome content, its on the Chrysler Building, all the shiny bits, stuff is so durable, they've only had to clean the building like 2-3 times since construction.
SmokeyTheBear said:If you can get it you really want 316L for that liner.
goathead said:SmokeyTheBear said:If you can get it you really want 316L for that liner.
I actually went with a 316Ti smooth wall liner that is.013 thick opposed to .005.
SmokeyTheBear said:goathead said:SmokeyTheBear said:If you can get it you really want 316L for that liner.
What did they ask for that?
That would also be a very good choice.
goathead said:SmokeyTheBear said:goathead said:SmokeyTheBear said:If you can get it you really want 316L for that liner.
I got a 4" x 25' for $299. The standard .005 was $259 so I figured for the extra $40 it would be worth upgrading.
mhrischuk said:BrotherBart said:This is where they get ya.
According to Olympia Forever Flex is 316Ti
(broken link removed)
This is a little scary. Does anybody ever remove and inspect? If not there could be a lot of this going on without anybody knowing it.
Some facts here
