After a look around here, it seems relevant to mention my chimney is 18' outside, excluding the cap, 90 & piece going through the wall. I just put it in to code. It's starting to make sense...
I'm probably not going to put in a flue damper cause the stove is working fine. But to not mislead, I think the "air tubes" are limited flow by the outlets, the secondary ~1"x2" inlet doesn't start to change the flow until ~50% restriction.
I'm glad I got to learn on this pita...
If you split the wood thinner, it burns, if you put more in the stove, it burns hotter
I've learned to run the stove hot on the coldest days & I can keep my NG furnace off, otherwise I can't really burn hot/clean enough.
It seems like everybody is getting loads of creosote out of their chimneys, I wonder if that's keeping more pollutants in the chimney & out of the air ?
I've been able to run the stove this season without any additional splitting, I rented a log splitter & split it all ~7 montre ago. They're about 1 - 4" thick splits.
The wood aint gray & still smells green, now that I'm into the middle of the pile, but it can be loaded to 700 flue temps & is working fine as I've never put wood into the thing that wasn't alive the same year
Happy New Year
