my last bill was higher that i was expecting.....$56 for the month of October, my previous 3 bills were around $16 .........but i have a solar system on the roof....
Teddy1971 said:chrisasst said:Teddy1971 said:chrisasst said:DVR's... I heard that DVR's use alot of energy because it is always on. Did you get one of those?
I have a Kill-a-Watt Unit and was surprised to see that the DVR's use 45 watts each and must remain on to record shows. This is the reason why we installed Solar Panel this past spring. It made a huge difference in my electric bill. My Bill for Aug 08 was $450.00 my bill for Aug 09 (Post Solar Panels) was $120.00.
How much did it cost for the solar panel system. I really want to do this but no clue where to start.
The breakdown is as follows:
$38500 Gross Total Cost of System (5 Kw System)
-$19500 NYS Rebate paid directly to installer
-$5700 Federal Tax Credit
-$4750 NYS Tax Credit
$9050 - Net Total Cost of System
Plus the appraised value of my house increased by $20000 which means I received $11000 of equity in my house for free. It would be great if everyone was able to get solar. The incentives are just too good to pass up. NYS is running out of incentive money quickly.
Firenutz said:I just got my bill for October/November and it's only $20 shy of what it was in the summer with 2 window air conditioners running 24/7. I looked at the kilowatt usage graph for the last year and the months after I installed my pellet stove (Jan.,Feb.) were higher than any summer months. So far it really only comes on at night. I'm really starting to wonder if this thing was a wise investment.
Teddy1971 said:This will be my first winter. But when it snowed a couple of weeks ago the snow covered the panels but melted within a couple of hours of daylight.
Firenutz said:I did turn up my electric hot water heater a couple degrees now that I think about it. I know those are a big drain on electric but our water was just not hot enough.
Firenutz said:.....I did turn up my electric hot water heater a couple degrees now that I think about it. I know those are a big drain on electric but our water was just not hot enough.
Firenutz said:....We couldn't even fill a hot bath with it before and we would run out of hot water. I've been looking into getting a tankless hot water heater.
It's a fairly small tank since we only have a doublewide. I don't know how old it is but it looks like new. I don't know much about them. I had to learn online where the stupid temp control knob was. There are 2 of them and they are under metal covers on most electric tanks. It's just the wife and I using it. We have a problem with public water ruining our clothes because of the chlorine content. The guy from the water authority told me if the water isn't hot enough in the tank then it doesn't off gas the chlorine as much. Our clothes are getting bleached and we haven't used bleach in 2 years!macman said:Firenutz said:....We couldn't even fill a hot bath with it before and we would run out of hot water. I've been looking into getting a tankless hot water heater.
That isn't a product of too low a temp, that's just a water heater that just doesn't have enough heating capacity(rise I think it's called?) to keep up....how old is it, what size? How many people in the house using hot water, etc?
Firenutz said:It's a fairly small tank since we only have a doublewide. I don't know how old it is but it looks like new. I don't know much about them. I had to learn online where the stupid temp control knob was. There are 2 of them and they are under metal covers on most electric tanks. It's just the wife and I using it. We have a problem with public water ruining our clothes because of the chlorine content. The guy from the water authority told me if the water isn't hot enough in the tank then it doesn't off gas the chlorine as much. Our clothes are getting bleached and we haven't used bleach in 2 years!macman said:Firenutz said:....We couldn't even fill a hot bath with it before and we would run out of hot water. I've been looking into getting a tankless hot water heater.
CanadaClinker said:...... I have been told that the factory temp of 140F was chosen because it takes longer to scald than say 160F. Also, 140F is sufficient temp to kill any growth of bacteria that might proliferate in 120F temp in the tank.
macman said:CanadaClinker said:...... I have been told that the factory temp of 140F was chosen because it takes longer to scald than say 160F. Also, 140F is sufficient temp to kill any growth of bacteria that might proliferate in 120F temp in the tank.
Interesting Clinker....I'd never heard that before. Every place i read about water heaters say that normally nothing more than 120 degrees is needed. Reduces chances of scalding, and saves a lot of $$.
As I mentioned above, I've had mine set at 120 forever, and it is PLENTY hot.
Also, sounds like you may be onto something with his heater problems....one element may not even be working. My guess is that the tanks just too small.
CanadaClinker said:......hey Mac.....if you are on city chlorinated water, the chances of growing stuff in the tank are minimized... if you are on rural well water then the risk is probably more...... some day I can tell you how I was trained to get rotton egg sulfur smell out of a tank... :-S
Most tanks are insulated very well these days to keep your $$ in the tank rather than escaping and heating your house. (electric heat). A quick test to how much its leaking heat is to put your hand on the outside of the tank.........if its cold then your are keeping your heat and $$ in the tank...if its warm, your heating your house. They used to sell tank blankets which were basically an insulated cover for the tank but I haven't seen them in years.
They say the best thing you can do is insulate the first 10 feet of pipe coming from your tank with that slip on foam pipe insulation....I did all my hot water pipes right to the taps.... cc ;-)
macman said:CanadaClinker said:......hey Mac.....if you are on city chlorinated water, the chances of growing stuff in the tank are minimized... if you are on rural well water then the risk is probably more...... some day I can tell you how I was trained to get rotton egg sulfur smell out of a tank... :-S
Clinker, you don't have to tell me about the sulfer removal....I have the system in my basement!! Big tank w/ bleach & water, pump, injector, carbon block, etc.....been there, done that! LOL (not anymore, though...switched to town water).
Yep, outside of tank should be cold. But I think they still sell those blankets.
Another method to keep hot water from "disappearing" is to put "heat traps" in your water lines into and out of the water heater. You can buy ready made ones that work on temp, or re-do your pipes so they resemble the trap under your sink....it keeps the hot water from rising.
chrisasst said:Teddy1971 said:chrisasst said:Teddy1971 said:chrisasst said:DVR's... I heard that DVR's use alot of energy because it is always on. Did you get one of those?
Wow...can you loan me some money...![]()
CanadaClinker said:macman said:CanadaClinker said:......hey Mac.....if you are on city chlorinated water, the chances of growing stuff in the tank are minimized... if you are on rural well water then the risk is probably more...... some day I can tell you how I was trained to get rotton egg sulfur smell out of a tank... :-S
Re....."Clinker, you don't have to tell me about the sulfer removal....I have the system in my basement!! Big tank w/ bleach & water, pump, injector, carbon block, etc.....been there, done that! LOL (not anymore, though...switched to town water)."
......the sulfur bacteria I refer to is breeding inside the hot water tank..... just the hot water stinks horribly of rotten eggs and black specks in the hot water.. :-S ... one or 2 back-flush treatments with hydrogen peroxide usually kill it.... have done it several times for customers and it cleaned it right up.... just suck the peroxide in a hot water tap back into the tank (there's a procedure to doing this easily).
......yes heat traps are also a great idea too to keep the hot water from migrating up the hot water pipe out of the tank....![]()
