bokehman said:Is it really "tropical". What are your typical highs and lows for the time of year?BrotherBart said:colder than usual here in balmy, tropical Virginia
55 high and 35 low.
InTheRockies said:I've been burning 24/7 for 2 months now. (It has been a cold year with almost no summer here.) This is my first year with the new stove so I wasn't sure how much wood I'd burn since it's supposed to use less wood than the old smoke dragon. Unfortunately, if our heating season this winter is anything like last winter, I'll be heating til mid-June. (Seriously, it was cold enough you needed to heat the house in the mornings through mid-June.) I suspect I'll be using 5 cords if I have to burn that long. Once hunting season is over, the bears will be asleep and, if we don't have a lot of snow on the ground, I'm going to get a permit and head into the forest to start working on next year's pile.
70/50 here, but feels freezing to us though.BrotherBart said:55 high and 35 low.
JAmuso said:This is my first season with the insert so I can't answer the question other than saying it's brutal in CT temp wise so I am burning a lot. I do have a related question....I do know that I will have to burn hotter to account for the cold temps. Burning hotter means more wood. I get that. I come home after work to a pretty cold stove and a cold house. Down stairs about 60 - upstairs about 58. I burn hot until bed (which is only a few hours) ....and get up and down stairs is in the low 60's (happy with that) I turned on the thermostat upstairs (uuugggghhhh) to keep it between 58-62 and take the chill off while getting ready for work.
I have a medium insert, 1800sq ft house...sided, insulated, good windows etc.....
Are my cooler temps in the house normal - and if i was able to be home and burn hotter - i'd have no issues getting into the mid-upper 60s? I dont need to be in the 70's or anything crazy like that. I'm just wondering if i got too small a stove?
I have noticed with the cold temps - the stove is burning much better..easy start ups...glass is staying cleaner. I'm mostly happy with the wood i'm burning - and the stove thermometer is running higher than ever.
Is this all normal? Not the rambling - i know that's not...
Smokeless said:JAmuso said:This is my first season with the insert so I can't answer the question other than saying it's brutal in CT temp wise so I am burning a lot. I do have a related question....I do know that I will have to burn hotter to account for the cold temps. Burning hotter means more wood. I get that. I come home after work to a pretty cold stove and a cold house. Down stairs about 60 - upstairs about 58. I burn hot until bed (which is only a few hours) ....and get up and down stairs is in the low 60's (happy with that) I turned on the thermostat upstairs (uuugggghhhh) to keep it between 58-62 and take the chill off while getting ready for work.
I have the same insert... 1400SF ranch... Its' been work keeping the house at 71,72 degrees. Seems likes my place likes to run at around 68. Too cold for me, when I thought I would be able to heat my place to the point of opening windows, etc. like "everyone else" claims.
According to these forums I have to install a block off plate to get more heat. My professional installation/installer didn't know what a block off plate was and said that the chimney cap sealed the chimney. So that's the only thing I can think of as a reason why I can't get the heat to the upper 70's. (Not that I want it to be 79, but supposedly a wood stove should be able to cook you out of the house. 68 is not cooking you out... neither is 72 or 73).
I've been wondering if I bought too small as well. It would really piss me off as money was not the issue. Buying the right size was the issue and I was advised to get the I2400 (1000-2000sf), the I3100 was supposed to be "too big" (1800-3000sf).
Like most Americans, "bigger is better", I should have stuck with the gameplan!
offroadaudio said:I attribute the low temps. to Global Cooling - now the Polar Bears are happy, but the Crocs are all pissed!
On topic:
I always THINK I have enough wood, and then 3 - 4 weeks into the season I see that big hole in my pile and worry weather I'll make it.
I think it's a little psychological - You look at that nice big stack all summer, it's level across the top with sharp corners - and then that hole develops
and it just doesn't look as stout anymore.
Backwoods Savage said:InTheRockies said:I've been burning 24/7 for 2 months now. (It has been a cold year with almost no summer here.) This is my first year with the new stove so I wasn't sure how much wood I'd burn since it's supposed to use less wood than the old smoke dragon. Unfortunately, if our heating season this winter is anything like last winter, I'll be heating til mid-June. (Seriously, it was cold enough you needed to heat the house in the mornings through mid-June.) I suspect I'll be using 5 cords if I have to burn that long. Once hunting season is over, the bears will be asleep and, if we don't have a lot of snow on the ground, I'm going to get a permit and head into the forest to start working on next year's pile.
Mid June! Yes, I remember driving through Colorado in early June and driving through snow, sleet and thunder storms. Then in Utah the next day we drove threw several inches of fresh snow! Of course, that was followed by turning south and getting into some extremely warm air...
We've definitely burned more than last fall, but last year was extremely warm too. I'd say this year has been over all a little below normal temperature but very little. Naturally we are getting hit now with the arctic air so it makes people think.
As for the woodpile, I guess the 21 cords will last us okay. lol
Is it in an exterior chimney? 2.3c.f. should be good for a 10 hour burn if your wood is big enough and you load it right up. How well is the wood seasoned?JAmuso said:i can deal with 68...i'm not sure i could've gotton a bigger stove even if i wanted one.
JAmuso said:Smokeless said:JAmuso said:This is my first season with the insert so I can't answer the question other than saying it's brutal in CT temp wise so I am burning a lot. I do have a related question....I do know that I will have to burn hotter to account for the cold temps. Burning hotter means more wood. I get that. I come home after work to a pretty cold stove and a cold house. Down stairs about 60 - upstairs about 58. I burn hot until bed (which is only a few hours) ....and get up and down stairs is in the low 60's (happy with that) I turned on the thermostat upstairs (uuugggghhhh) to keep it between 58-62 and take the chill off while getting ready for work.
yeah...i'm not sure - i can deal with 68...i'm not sure i could've gotton a bigger stove even if i wanted one. I too went by the manufacturers specifications for sizing. I dont have a block off plate either...they insulated around where the damper of the fire place was - and around the liner....I do feel - that on a weekend if i'm at home - running it at a higher settting - and feeding this stove as necessary - we'd get to the temps we want. Issues arised due to work - away from home for 10+ hours - and on cold days...big cool down in the house. Where i was hoping to not have the theromstats on - i'm going to have to use them to keep the temp from getting too low...i wont be setting anything above 62. If the temp at home is 60-62 - i should be able to get into mid 60's which on work nights is fine - vs. going from upper 50's to low 60's.....I will have to deal with that reality and just know i'm still saving compared to oil.....
Hopefully it won’t be like the ‘77/’78 winters. Does anyone remember those two winters?
They're talking full cord. A face cord is barely enough to have one fire a day for a month.turtletrucker said:when you guys talk cord. Are you talking face cord or full cord
