I just put down a deposit on the new Woodstock stove! The problem is we still don't know clearance requirements and therefore hearth size. I may just opt to extend the hearth size by adding to it, but if the R value needs to increase for the new stove I will need to completely replace it.
I installed the hearth - it's 1/2" cement board on top of a layer of Thin Set Mortar, and its screwed down onto a plywood subfloor. There is a layer of brick (again mounted with Thin Set Mortar) on top. Its all surrounded by hardwood floor (which I just installed).Bummer I wish I just made everything much bigger!
Has anybody ever tried to demo out such an installation? Seems like it would be hard to get to to the screws through the Thin Set, and how much damage will there be to the plywood when I try to chisel out the cement board from the Thin Set? :bug:
