Any "small short" stoves like this one?
mlexp
22
Anyone know of a current manufacturer making a stove with these dimensions or smaller? I have a very small fireplace opening and have used the standard small Vogelzang boxwood stove. But I have to take the legs off and put the stove sideways on a cast iron fireplace grate to BARELY make the height clearance. And 3/4 of the stove is IN the fireplace because the pipe cant turn coming out the top, it goes straight up the chimney. I use a fan to circulate the air around the stove and come out the other side in a U pattern. But I dont want to continue this. Take a look at this Better N bens Model 02052 and see if you of anyone making something like this or smaller. Thanks.
http://cgi.ebay.com/Wood-Stove-Bett...ryZ41987QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
What is the height, width and depth of your fireplace opening? Also how far does the hearth extend out in front?
Yeah, I can think of quite a few stoves, but the dimensions of the fireplace and hearth are really neded.
^^^^^^^^^^^^^ what he said^^^^^^^^^^^
if we know what size the firebox is, we can be much more helpful in advising what stoves to look at
some ideas for you:
http://www.marinestove.com/codinfo.htm (these may be too small!)
(broken link removed to http://www.drolet.ca/product.aspx?CategoId=1&Id=179&Page=spec) (a little more reasonable, and still a decent size.... but EPA exempt somehow)
(broken link removed to http://www.jotul.com/en-us/wwwjotulus/Main-menu/Products/Wood/Wood-stoves/Jotul-F-602-CB/) (there was some talk on this forum about switching the tall legs on this with shorter legs)
