M
MasterMech
Guest
(though what moron puts the starter under the intake manifold)
Toyota ain't the only morons to try it.
GM. 1st gen Cadillac NorthStar V8's
Toyota can't build a v6 to save their life... for whatever reason... they've got 4cyls down.... and the V8's aren't awful (though what moron puts the starter under the intake manifold)
those weren't exactly some of GM's best work either....Toyota ain't the only morons to try it.
And an appetite for oil.The Northstar V8 was a very good engine actually, just had a poorly located starter.
For some, an engine is a POS if it doesn't go 400,000 miles without a single failure (including sensors and accessories), burn zero oil, and get 40 MPG.
I don't know of any gas engine that does that.
My wifes old corolla got that bank lean code a lot. Before she met me mechanics tried to sell her all kinds of fixes. The issue is the MAF would get crudded up, I'd clean the wire with electronic cleaning spray once a year all set.
its funny what is a big issue to some. I had an 87 dodge charge with the iron block slant 4. Bought the car for 200 bucks, 250k and still going. We once had a Honda civic though that needed a valve job at 90k and blew the head at 180. But still I trust Hondas more and have had many many since.
Case in point I know many don't trust Honda automatics since the rash of failures 10 years ago. But they have been redesigned since and I have no worry about the unit in our 08 pilot. Just changed out the Honda atf for redline synthetic and forget about it.
Her Corolla was an 01.
I know that Honda themselves replaced the z1 fluid with a new synthetic formulation called dw1. But I'll still trust redline better. Redline MTL cured the sticky 2-3 synchro in my acura.
Did the 95 have a maf or a map sensor? I don't know Toyotas that well...
Had to hunt around but I found the right parts guy...To be clear, the loose clamp in question was between the airbox and the throttle body...
So, yeah- start, falter, die... over and over.
Still throwing the fault from the disconnected VVT sensor but I think I know where I'm going with that.
Gotta love it when a plan comes together! A good parts guy is worth his weight in gold!
I beg to differ with you. Get yourself a 1993-94 era V-6. Wife has one and it's the best engine/vehicle combo I've ever owned, so far nothing but routine maintenance, just over 180,000 miles this past weekend. Kind of like the GM 3100 V-6 engines from the same era, I've seen many of them go well over 300,000 miles, and still going strong.Toyota can't build a v6 to save their life... for whatever reason... they've got 4cyls down.... and the V8's aren't awful (though what moron puts the starter under the intake manifold)
