DeanB said:
Ok I'll do a search, I never knew there was such a thing.
Keep us posted on what you find. I think it would be the best, and possibly only, solution for my setup.
I counted today, it looked like the our chimney is about 7' from the high side of the roof to the top. The roof is a 12/12 (45*) pitch, and the chimney sticks out about half way up. This is NOT something that you can get to easily to clean from the top :gulp:
From the bottom it's not a whole lot better. We call our setup the "brick rocket" because it looks like one! ;-) In the living room it is a section of a circle, I'm guessing about a third, that fits into one corner and comes down to about 30" off the floor. There are two triangular brick "fins" that come off the chimney about 6' up, and extend down each wall at about a 45* angle to the floor. The hearth across the corner between the fins. The bottom of the round part of the chimney is supported by a couple of buttresses that come out from the wall. It is an impressive structure to say the least, the mason that built it did a nice job. The liner comes straight down to the bottom of the main chimney section, and sticks out a few inches, then goes into the crosspiece of a "T" fitting. The other end of the crosspiece is capped, and is maybe 18" off the floor. The base of the "T" connects to the flue of the stove via a 6" -> 8" adapter.
The sweep pulls the cap off and shoots up from the bottom with the flexible rod I described, I'm not sure there would be enough room to get a sectional rod around the bend, and it surely would be a bear to get the sections connected.
I also tried to get a rough measurement for overall height - doing the "tape measure extension" game, I got to within about a foot of the trim board at 17', holding the bottom of the tape at what I estimated the height of the first floor flue would be. Allowing for the space I couldn't get the tape up to, and general fudge factor, I'm getting between 25 and 30 feet for the first floor flue.
Our backup stove is in the basement, and is a bit easier, perhaps. It has a similar layout to the upstairs hearth, except the wall between the "fins" is a flat diagonal across the corner. There is a thimble about 5' up, that feeds into a second liner in the same chimney structure, although this second liner is quite far into the chimney because it runs "behind" the first floor liner. There is also a cleanout for this flue inside at the hearth level.
However adding another 8' for the extra floor means I need about 35 to 40 feet of rod... I'm guessing the sweep's rod was probably about 50' on that coil - at least it looked like it might be.
Gooserider
