Antique wood stove hearth requirements
The offset is fine. Yes you can add a stove pipe damper. Glass is non-combustible but can be sensitive to heat extremes inside vs out. It may be fine, that's just heads up. The main unprotected issue is the wood corner support behind the stove.
Yea I figured I might have to add a shield in the corner too. Good thought on the glass. I guess we will see how it does. I also read up a couple of your articles and links on here. Thanks for all the info and content. I am new here and can already tell you put a ton into this place. So again thanks.
Sent from my XT1060 using Tapatalk
