- Oct 3, 2007
- 1,539
I came up with another idea for a pole barn because the last one I was thinking of building would have been too small. This one will be 16 x 24, so not overly large, but probably the biggest I can accommodate on my .25 acre lot. Here's the basic idea:
-6 x 6 x 12' poles sunk 48" deep
-2 x 6 pressure treated girt board around the bottom
-2 x 12s bolted to the inside and outside of the tops of the 6 x 6s (is that overkill?)
-2 x 2 x 16 floor joists for the loft, 16" OC
-3/4" OSB subfloor up top
-Home built gambrel roof trusses made from 2 x 4 x 8s and OSB web plates on both sides spaced 24" OC
-Steel roofing and siding
-Sliding 8' wide door
-Compacted crusher run floor
I figure I can build it for about $5000 doing the work myself, the question is, is it a sound design? I'm basing it off of a barn I saw built on another forum and am pretty much copying it exactly. The guy was in Indiana so it definitely sees plenty of snow. Here's a cross section of the framing:
The goal is as small a footprint as possible with as much storage as possible, hence the huge gambrel truss. That's the part I'm wondering about the most. Should I use 1 x 6 bracing instead of the OSB webbing?
![Another pole barn idea Another pole barn idea](/talk/proxy.php?image=http%3A%2F%2Fi25.photobucket.com%2Falbums%2Fc68%2FBadfish740%2FPoleBarn_zps7446ea76.jpg&hash=d09527657fc33a9e1d4211cae03a5889)
