Hello everyone!
I've been on Hearth.com for several years as I've heated my old house with a catalytic wood stove for 7 years. I've since moved to a much larger house and I don't have good access to my basement, so I want/need to put in an outdoor boiler. We've seen a fair number of Heatmores and Central Boilers in operation (6 within 0.5 miles of our house) and we are convinced that they smoke too much and while I like cutting wood, I don't want to double my work by using an OWB. That leads us to a gasifier and then a ton of questions.
First off, here's my setup. We're in central Wisconsin, so it gets cold, but not anything like Northern Minnesota where I grew up. I've got a 5 year old house with 2X6 walls, well insulated but lots and lots of windows, including a sun room. The house is 2400 sq ft on the main level and 2400 sq. ft in the basement which I am finishing off with 6" insulated walls also. We've had a heat loss calculation done for our house and we were told that we would burn approximately 2300 therms of natural gas in our current furnace in one year. We have kept the thermostat set at about 60 degrees now and we have only burned an actual 1110 therms in the past 12 months. I/We would desperately love to move the thermostat up to the 70ish range next winter as well as heat my 3 stall, insulated garage.
How can I use these numbers to figure out boiler size? I've got the heat loss calulator downloaded, but I get confused in trying to make the right selections of all the options it gives me. I've called Cozy heat and was told that we were on the line between an EKO 60 and the 80. What about other brands?
Secondly, I have no problems building a small shack for the boiler, but can I get by with a "yard barn" type of steel structure that the local building places have for sale for about $300? Is there any advantages to a stick built shed? How big of a shed am I looking at building for just a boiler and a little bit of extra room?
Thirdly, I'd like to start pulling PEX into my basement now while I'm finishing it. What diameter PEX do I need to run to my furnace and hot water heater? Should I put in a manifold system or can I run just one loop from the furnace to the water heater to the garage and back to the boiler?
I've got a ton more questions and I'd love to hear some opinions.
Bill the Dog
Bill the Dog
My two cents would be, do you need such a large stove? It sounds to me after reading your house size and construction information. That you might just have more heat than you will know what to do with it.
