We are replacing a beat up '70s era VC Defiant stove which is impossible to control due to air leaks, interior damage and poor design. Damping the fire down enough for overnight burns generates significant creosote and running it hot can force us to open windows unless it is below freezing.
The heating area is an open design, 940 sq. ft. with a 175 sq. ft. loft, with a central masonry chimney with 8x12" flues. This area is above a basement that stays fairly warm from electric heat, with an open stairwell. The house is not super tight but mostly well insulated. Because of the basement heat we are comfortable without additional heat until the outside temperature drops below 40, unless it is windy.
Our wood is mostly red oak, cut to 16", split and stored in a shed for a year. The distance from chimney thimble to the top of the chimney is about 17 feet, mostly indoors.
The dealer recommends the F400 and I think it would be well sized for our situation. However, we really like the side loading feature of the F500 and wonder how well it would work in our house. We would like to be able to re-kindle a fire from coals after a 10 hour work day and also avoid over-heating the house when the temperature outside is above freezing.
What do you think?
What do you think?
