Hello everyone, this is my first post here. I feel bad about having my first post be a bunch of newbie questions, but then again I suppose I have to start somehow. ![embarrassed ;em ;em](/talk/styles/default/xenforo/smileys/embarrassed.gif)
I bought a house last fall, and only recently started using the fireplace insert that was in the house when I bought it. First of all, I don't have a manual of any kind for it. It seems to be the same insert as in this link, which the person who posted the video calls an "Ultimate BV Large Wood Fireplace Insert." However, when I search this very little comes up, so I can't find a manual.
The chimney sweep said that the stove has a catalytic converter, which should burn the smoke once the fire gets hot enough. I did some research on catalytic stoves, however, and this insert doesn't have a thermometer or any way of "engaging the catalyst" (as many of the websites I've seen say) unless that just means closing the damper. I do see that the catalyst starts glowing when the fire gets hot, but it stops glowing shortly after I turn on the fan that distributes the heat throughout the house. The fire gets the house warmer, but I don't feel like I'm doing quite the right thing with the catalyst because the increase in heat once it gets going is relatively modest, and the catalytic converter stops glowing during the fire.
Should I be closing the damper all the way? The chimney sweep suggested leaving it open a tiny crack, "just in case," but I wonder if that is preventing the catalyst from fully lighting. Also, there are two small vents at the bottom that can be opened and closed. Should I be closing them once the fire gets going? A lot of information I have found discusses the problems with letting the fire smolder, and since I live in an area with frequent bad air/ no burn days I want to burn as cleanly as possible, but it seems like a hot, subdued fire is what I should be trying for to get the converter working.
Thank you!
Thank you!
