let me know how you make out with that, same issue here maybe shoot me a PM incase this thread gets lost. ThanksI'm gonna try one gasket diameter size bigger and see if it helps. If not, I'm popping the glass out of the non-seal door, tack welding a 'ridge' onto the lip that goes over the other door's gasket, and re-installing the glass. Sounds like a lot of work but I have the tools and know-how to do it, it shouldn't be too bad. Worse part of the job will be re-installing the glass in the door while trying to re-use the old gasket.....
Hopefully the thicker gasket will do the trick. I'm going to talk to the dealer that sold me the stove and see if he has anybody else having this seal problem.....
in the NZ 3000, and the Quadrafire 7100, you load the splits longways so the end of the splits are nowhere near the glass..... in my stove, it's definitely an air leak at the center gasket.Just a thought, but how close are you loading the end of the splits to the door? I have been cutting my stuff to about 16" although it will take near 18 or so. but with the splits loaded N-S and real close to the glass it will off gas out the ends against the glass. Of course here it usually burns off though. Interested to see if you can seal between your double doors or not.
When I get a thicker replacement gasket, I'll post my results on this thread.
Hi Greg, I haven't changed out that gasket yet. Been too busy to do anything with that stove, trying to get the trim and floor in that room so we can get moved into it. My glass still gets black, but not as bad as it was. I did a small modification on the door latch on my Napoleon, and it helped alot, but still leaking air at the center gasket. When I get around to changing out that center gasket I'll post my results.....Hi Scotty,
My name is Greg, and this is my third winter burning with my Quadrafire 7100 FP. Just curious- did you ever resolve the glass getting smudged up issue? I am experiencing the same problem. Another question: I have experimented loading wood both directions E/W and N/S- is there a reason you prefer to burn E/W? It seems that I can pack the splits tighter when I load N/S and I don't have to worry about one rolling down onto the glass. The smaller length of the slpits (12-14in) also seem to season better for me. Always trying to learn and improve.... Thanks.
When I throw on some Pine, I see black smoke coming off of it. That smoke is probably loaded with pitch. If I put a piece too close to the glass, it will be gunked over in no time...But what surprised me once though was burning some pine boards up that had been laying around here for like 20 years..man did they burn..I mean hot..real hot.
Seems like I could only cut the air all the way and do the cat run or just add a little more air then it was like the gates of hell.
Thing is even that very seasoned pine smoked my glass on low burn.
I'm guessing from the wood out gassing so fast.
Make sure your wood is super SUPER dry, and I found that smaller splits seem to do much better in regards to not making the glass black. I have found that my fireplace likes to be good and hot before you shut the doors down, and when you get it good and hot it seems to NOT blacken the glass as badly.
I think all stoves/fireplaces/inserts have their own way to burn best.
Hi Scotty,
Word of caution, be extra careful when reninstalling the glass. Would be a good time for a new gasket for it if needed. Just barley snug the screws. You can always snug them a bit more after burning a few fires to let it settle in.I'm gonna try one gasket diameter size bigger and see if it helps. If not, I'm popping the glass out of the non-seal door, tack welding a 'ridge' onto the lip that goes over the other door's gasket, and re-installing the glass. Sounds like a lot of work but I have the tools and know-how to do it, it shouldn't be too bad. Worse part of the job will be re-installing the glass in the door while trying to re-use the old gasket.....
