save# said "without that heated draft, the by products of the combustion will accumulate and obstruct the air flow to the point that the stove may not function."
This seems like an assumption that lacks a good basis. "products of combustion will accumulate and obstruct the air flow" How is that not what happens when a stove is working perfectly -over a long period of time? The products of combustion are ash and carbon, -they're produced regardless of the temp in the vent. They are no less likely to accumulate at a low vent temp than at a high temp. The only way to prevent air flow obstruction is the occasional vent cleaning.
"these stoves are very specific about what type of venting material and circumstances for installation are needed for proper functioning." Yes, very specific, but not for proper functioning (except in regard to pipe size/length/angles) but for conforming to government safety codes, most of which are written for wood stoves.
"There is a reason that you need heat in the exhaust. If the temp drop below 200 degrees it will condensate causing creosote to form." I'll believe that's true but I also believe that it's more pertinent to wood stoves than pellet stoves. Pellet stoves, with the combustion air strongly feeding the flame with oxygen, burn at a temperature high enough to burn the substances that could become creosote, so if they are burned they turn into soot at worst, and carbon dioxide/monoxide at best. Lower burn temps. are what's responsible for creosote formation, not lower vent temp. And after all, not everything that burns can form creosote anyway, candles, lamp oil, gasoline, etc. I'm under the impression that the substances that form it are found in the bark of trees -where the sappy substances are. So the question is, do makers of top quality pellets even allow bark into their mix? I would think not because it would also create more ash and wouldn't burn as hot. I think the core wood of trees doesn't contain those undesirable substances. Anyone know anything different?
"I’ve heard of all of the 4 above being done, including removing part of the top of the stove so a fella could cook eggs on the heat exchanger." If by "the heat exchanger" you're referring to the heat exchange tubes of a pellet stove, I would assume that fella removed the top cover of his stove to expose the roof of the burn chamber, not the tubes underneath it. With my Whitfield, it's not possible to remove the stove roof since it's part of the welded-together body. All stoves are probably make like that.
About condensation forming in the vent pipe due to low vent temp., I think that would violate some law of physics. It's COLD metal that causes condensation, like in a cold car exhaust pipe and muffler . So it wouldn't matter if the pipe is only very warm, not hot, it would have to be cold for water to condense on it because only cold causes H2O to change from a gas to a liquid.
