The stove is in the temperature mode.  It seems to get to the desired temperature and at some random point, the fans spin down and the igniter turns on.
I'm guessing that when the stove is at the desired temperature, the stove may reduce the feed of pellets. The re-ignition happens even when the displayed room temperature is the same as the set temperature. The only thing I noticed was that the exhaust temperature was reduced to somewhere between 160-200 degrees when this happens. Unsure why the stove is just not shutting down when it reaches the desired temperature. Also, this happens constantly - at least every hour or two. It used to work just fine. Any ideas?
