I took my Jotul C450 out of the garage and into the yard for a test burn. With air control all the way open it would not burn with doors closed, smoke was pouring out of the door edges, and glass edges. I was thinking it would just vent out the flue collar like it should with a 15' liner attached. I am guessing that since there was no liner attached, there was no draft created to keep the fire going? Also, I read a lot of references to airtight stoves. Since smoke was leaking out the closed doors, it is not airtight. This insert was a Craigslist find taken from a foreclosed home. The DOM is 2005, and the chimney cap is fairly clean indicating low use. How air tight should it be? This insert also has a 3" round duct to attach an outside air kit. I would have to knock a hole out the back of my masonry fireplace to run OAK into the garage. There is no gas in there to worry about, but wouldn't it create a hole for cold air to come in the house through the insert? The rope seal around the doors still looks new, no yellowing. The glass is held in place with metal clips screwed to the side. Suggestions, thoughts appreciated.
