BKVP
One other observation, FOR ALL WOOD STOVES, the first step in the combustion process is to deal with the water that is in the wood. As we all know, the level varies from piece to piece, therefore load to load.
If you load the stove at 8:50 p.m., shut it down at 9:00 p.m. and go to bed, you have created a "crock pot". In any stove, this is not ideal. In a cat stove, it can suppress cat temps and in secondary combustion designs, it keeps refractory or other elements for thermal destruction from getting up to temperature.
If you were to load a stove 1 hour before going to bed or off to work, run it hotter, you deal with the moisture at elevated temps.
We wood burners, caring about out own stoves, our neighbors' right to clean air and of course the image associated with being wood burners need to advocate (share) for anything that we have learned will improve performance and reduce smoke.
