Air quality while using the woodstove
Exactly. Our fist son great ,the second- that son of a gun was difficult from the get go, took a number of years of military service to straigten him out ( guess who has 4 boys of his own now - Karma) also have a very nice daughter, but don't mess with her the results will not be healthy.
I also noticed an increase in pm2.5 and 10 levels using the stove, I created this slight suction from inside, I didn't understand if the powders come out of the stove or are volatilized with the high temperature
[Hearth.com] Air quality while using the woodstove
Maybe the airflow increase from the heat loops and/or fans stirs up the dust and keeps it air borne longer?
I don't have fans, I think the dust comes out of the stove, it's not much anyway, from 10 units pm 2.5 I'm reaching 20 and pm 10 from 20 arrival to 35. I wonder, it seems to me that on the furniture, on the table, we find a light dark powder, not visible, but if I pass a wet cloth, it darkens quite a bit, and in any case in Italy everyone talks about this dust on the furniture, burning wood, does this happen to you too?
Yes more dust during the burning season. maybe some comes off the wood as it waits to be burned next to the stove, some smoke / ash comes out every time the door is open. Ash definitely gets in the indoor air every time you clean the ash out, even with an ash pan. But the ash pan users get less ash release into the air when cleaning vs. shoveling into ash buckets for sure.
Reactions: stovexxx
I did figure out that the pm2.5 and pm10 were back drafting from an adjacent flue. I still get high TVOC when running the woodstove. Still puzzled why I am getting an odd smell from the woodstove.
Outside air intake might still be a good idea, to prevent the stove from sucking air out of the home and creating a partial vacuum there. I find indoor air quality to be better than outdoor air; running a stove without outside air intake would suck dirty outside air into the house.
I replaced the back gasket a couple weeks ago amd noticed a plastic adhesive on it. I did a test burn today and still get a smell that doesn't seem normal.
I used a map gas torch to the outside of the stove thinking maybe something was burning on the outside and had no luck.
I put the torch on the inside and it seemed to smell as soon as I heated up the top plate of the stove.
Not sure where to go from here. This stove was made during covid. I wonder if it is due to bad manufacturing.
Update: I tried limiting how hot the stove burns by slowing down the air intake. If I let it burn un restricted the smell goes away. I cannot confirm 100% that this limits the amount of TVOC in the air.
