As Jay said your EVL is fine.
Could you provide a picture of your control board from both sides?
.....................................The board is ok, no burn spots no damage... Not sure what your looking for, but I did look over the board and verify all's good.
Could you explain exactly how you clean your stove?
.....................................I brush the heatexchanger, scrape the grate, vac the ash trap, fire box, remove the firebrick &brush; and vac behind that. vac out the T cleanout, vac out the feed chute. Run the vac across the door gasket to get the ash off of there, and down in the window seal.
When were the door and ash pan gaskets replaced?
.....................................The stove is a month old, the gaskets were never replaced. The door gasket has a good seal all the way around, and the ash pan doesnt have a gasket because it has a slide gate that seperates it from the firebox. Thats sealed good as well.
Do you have a manual? If so can you provide an on line copy?
..................................... http://www.fiamma.us/images/Lennox/Profile-stoves(II&OP
.pdf
Can you provide pictures from above, below and all four sides of your grate when cleaned, I'm looking for possible warping (air flow bypass), and a top view of the area the grate sits into?
.....................................I'll take some.
I have a link for you to look at:
http://www.butkus.org/whitfield_pellet_stove.htm
