Hello, looking to improve upon our current Superior zero clearance fireplace in our mountain cabin.
From what I’ve read it sounds like there aren’t very many insert options that work with this fireplace?
Also, does anyone know if any of the inserts that do work are 2020 EPA rated and eligible for federal tax credit? and/or California smoke reduction program rebates (‘emission rates not to exceed 2.0 grams/hour”)?
Another thing I read that people might do in cases like ours is remove the whole old unit out and put in a different insert, or make an alcove for a stove?
More context:
The cabin is about 2000 ft.² and is located at about 7500 feet of elevation.
Looking to use this as the primary heating source for the cabin during the winter. I have ample free supply of wood nearby.
Couple of photos of the existing unit attached for reference. Dimensions of the fire box space: 42”w x 27”h x 21”d.
Cabin is two stories and fireplace is located centrally in an open floor plan with sleeping loft directly above.
Suggestions and ideas greatly appreciated.
Thank you.
![Advice on insert vs stove to replace Superior zero clearance fireplace Advice on insert vs stove to replace Superior zero clearance fireplace](https://www.hearth.com/talk/data/attachments/318/318278-8e2be67789e9205d36b08bbea801e060.jpg)
More context:
Thank you.
![Advice on insert vs stove to replace Superior zero clearance fireplace Advice on insert vs stove to replace Superior zero clearance fireplace](https://www.hearth.com/talk/data/attachments/318/318277-251f9c8cfe7d740220ae35919a7786e2.jpg)
