I made the decision to make my harman insert pellet stove have an outside air intake
And I need to drill a hole.
It needs to be 3 inches ?
Lots of choices and options. I have a relative with a rotary drill / hammer drill, Lots of 9 inch madonary drill bits.
I read online I might need a Core Drill Bit which costs $100
When I was a kid I drilled a hole through concrete with little drill bits and a chisel and hammer.
$100 for a special core bit isn't that bad but not sure if my uncles rotary drill is the correct style drill for a "core hole saw
I saw there is diamond, tungsten, carbide , Dry & Wet. It's overwhelming. I took some pics to help gather some advice from any construction people on here.
Thank you
I don't care if it's messy. As it will be concealed.
I assume I can drill some on inside and some on outside. And should start with 1 small pilot hole to find the location inside & outside etc.
Thank you for all and any advice.
Thank you
