6”x10”What are the inside dimensions of the current clay liner? My apology if you have already stated this.
An oval liner will work without removing the clay in that case6”x10”
That's what I was thinking. It looks like there is only about 15' of the chimney above the thimble. A 15' DuraLiner system would be around $1500 for materials.An oval liner will work without removing the clay in that case
Ok if it's cooking you out now that opens up lots of options.So with all of this information and my Kodiak is now cooking usafter the new insulation/spray foam going from plain cinder block walls. Which direction would you recommend I go? Not going to do anything until this heating season is over.
Yes I have to choke it down to where it’s flue temperature is around 250 degrees now, where before I’d keep it around 450. Flue dampening max and air inlets barley cracked open now.Ok if it's cooking you out now that opens up lots of options.
Ok so I would say most large stoves will work fine in that caseYes I have to choke it down to where it’s flue temperature is around 250 degrees now, where before I’d keep it around 450. Flue dampening max and air inlets barley cracked open now.
Any options to keep my current chimney set up… non catalytic?Ok so I would say most large stoves will work fine in that case
I wouldn't recommend running any modern stove through an uninsulated exterior chimney like yours honestly. One of the big 8" vent stoves (bk king or regency 5200) might work but I wouldn't recommend itAny options to keep my current chimney set up… non catalytic?
I plan to continue to heat the house for the next 20 years with wood as long as I’m able. It all started just wanting a glass door and better looking stove. Wife prefers the cast iron look.
Thanks so much for the help! What would you suggest to correct my current chimney situation? I’m quite handy regarding doing it myself just need some advice 😊 no way I’m paying 9k when I’m capable. This has a big eye opener for me and I want to do it correctly.I wouldn't recommend running any modern stove through an uninsulated exterior chimney like yours honestly. One of the big 8" vent stoves (bk king or regency 5200) might work but I wouldn't recommend it
An oval insulated liner equivalent to a 6" liner and a 6" stove. It can be duraliner or oval flex linerThanks so much for the help! What would you suggest to correct my current chimney situation? I’m quite handy regarding doing it myself just need some advice 😊 no way I’m paying 9k when I’m capable. This has a big eye opener for me and I want to do it correctly.
Are the catalytic stoves the way to go? They seem very finicky from what I’ve researched, are they that much more efficient vs a non catalyst stove?An oval insulated liner equivalent to a 6" liner and a 6" stove. It can be duraliner or oval flex liner
If you need low heat for a long time yes. They are also generally a bit more even heat output. If you are typically going to be burning harder no I don't think cat stoves make much sense.Are the catalytic stoves the way to go? They seem very finicky from what I’ve researched, are they that much more efficient vs a non catalyst stove?
I suspected this would happen. Congratulations. This work will pay off for the life of the house.So with all of this information and my Kodiak is now cooking usafter the new insulation/spray foam going from plain cinder block walls. Which direction would you recommend I go? Not going to do anything until this heating season is over.
The Ashford 30 will still work. It can run low and slow. If you want simple, with a good fire view in a non-cat, look at the Lopi Endeavor and Pacific Energy Super or Alderlea T5. The T5 can still provide a 12 hr burn and will run fine on a partial load of fuel. It's an easy breather so the shorter chimney will not be an issue and it has the cast iron look favored by her.Are the catalytic stoves the way to go? They seem very finicky from what I’ve researched, are they that much more efficient vs a non catalyst stove?
Liking the looks of the PE Alderlea T5 & T6... I like the larger fire box of the T6 but not sure if I would need that size? I have been baking out here since I finished up the insulation! Thinking I could burn it lower, guess I'm just used to a large fire box and cutting my wood in the 20" size.I suspected this would happen. Congratulations. This work will pay off for the life of the house.
I see a few nights going into the single digits this week… good idea I see how it goes. Right now in the 30-40 degree range & it’s always too hot 🥵There is a large polar system descending across the US. If it hits PA you may get a chance to see how the house heats with temps in the teens. If you're still in your skivvies and opening windows, then yes, the T5 would suffice. If the Kodiak feels about right at that temp, then go for the larger T6.
Maybe 8 cords cut & stacked as of now… another tri axel load not touched yet for next season. Soo not that big of a deal just used to using my 20” bar as a referenceIf you have many cords of 20" firewood already split and stacked, then the wider firebox of the Drolet 1800 (Osburn 2000) can accommodate them by loading E/W. If you don't have cords ready to burn, then it's time to get stacking. A modern stove really wants fully seasoned wood. The good news is that you'll be burning a lot less wood to stay comfortable.
What kind of burn times do you experience with the T6?I see a few nights going into the single digits this week… good idea I see how it goes. Right now in the 30-40 degree range & it’s always too hot 🥵
It depends on the outside temps. Our old farmhouse has pretty high heat loss. It would not fare well in New England without some substantial fuel consumption.What kind of burn times do you experience with the T6?
