The ICC Excel chimney I think does.thechimneysweep said:4) When you install the insert, install a stainless liner to the top of the chimney, because even code-approved double or triple wall ZC chimney doesn't meet the HT standard (that's what the quote from PE's manual above is all about).
http://www.icc-rsf.com/en/icc/Insulated_Stainless_Steel_Chimney
EXCEL is tested and listed to the ULC S-629 chimney standard. The ULC standard is generally considered the toughest residential chimney standard in the world. The USA standard requires the chimney to withstand three 10-minute 2100°F chimney fires. The Canadian standard requires the chimney to withstand three 30-minute chimney fires, three times longer than the USA.
After my father's house burned down from a chimney fire in his Selkirk flue, I not only went with the higher rated ICC but I also used no wood in the chase and lined it with a radiation shield.
