twigg, your eyes want a cast iron stove but at heart you're willing to go with a steel stove. The PE Alderlea series combines both together in one stove. I would try to see an Alderlea and judge for yourself. If you want the best of both worlds, it's a good place to start. (No PE doesn't pay me. Wish they did ).
The T5 is about $2000. Not far short of the Oakwood, in it's asic form. Looks like a nice Stove, but I don't see any real advantage over the Englander.
If we were to go for the Alderlea, we may as well spring the extra $300 for the Oakwood, which leaves us back where we started
If you think the Englander will satisfy your needs now and for the next 5-10 years, go for it. They are good solid stoves and will save you a lot of dough. But if you think that in a year or two there'll be a hankering for something in cast iron, then get the Alderlea or one of the other cast iron stoves mentioned earlier and be happy.
Regardless of stove brand, I'd look into 3 cu ft stoves if the intent is to heat a large area (like the whole house) 24/7. We're heating a 2000 sq ft old farmhouse in a milder climate with a 3 cu ft T6 and it isn't too big. With an open floorplan, the core of the house rarely gets over 74.
I was attracted by the very modest hearth requirement of the Alderlea, plus the swing-out top. OTOH, the firebox is under 2cuft.
We are probably going to swallow on building a 1.5R hearth (it's not that hard) and go with the Englander.
Just for info .... I emailed Englander and asked about the possibility of a bottom shield to reduce the hearth requirement. The reply was a not surprising *no chance*. The speed of the reply was very encouraging
The Englander should serve you well. Have you settled on the 30NC?
For the record, the T5 is 2 cu ft. The T6 is 3 cu ft. FWIW, I'd go with the T6 if going with the PE. The cast iron jacket softens the heat. This is not a highly radiant stove except from the front. The mass of cast iron does soften the heat and releases it slowly into the room.
