Hello master wood burners,
I just installed our new Jotul Oslo F-500 in our 27' Yurt here in Wisconsin. I completed the 3 break-in fires this weekend, per manufacturer guidelines, and the stove kept us warm all night despite outside temps in the 20s.
I am noticing an issue however regarding adequate draft (or perhaps intake) for this otherwise awesome stove. I am unable to maintain a secondary burn, even with the primary air intake open all the way to the right for maximum intake. If I leave it in this position, the fire gradually dies down and smoke begins to rise out the chimney pipe. If I crack the ash pan door, then of course the fire starts ripping again and I can see the secondary burn in action, and no more smoke out the chimney. The Manual says to never operate the stove with ash pan door open due to risk of overfilling, so I nervously kept a close eye on my stove temp and the fire all night, but I couldn't get the stove to burn properly with it sealed all the way up and only using the primary air intake valve.
I'm not sure if the issue is my chimney height or if there is some other troubleshooting I need to do with the intake?
I first figured I would address the chimney issue. Per the manual for the F-500, it recommends a minimum of a 15-ft chimney for adequate draft.
I am using a 6" double lumin galvalume class A exterior chimney. I used DVL (double lumin) stove pipe from the stove to the chimney-the stove pipe rises about 32" from the top of the stove to a right angle, and then attaches to the galvalume (via thimble) and out the wall. The chimney height from this point was just under 12 feet to start. After noticing this draft issue, I added another 36' section of pipe. The total exterior chimney hight is now around 14.5 feet. (If i add chimney+ stove pipe height =17'ft, ie total run from top of stove to top of chimney). I lit another fire and didn't notice much difference. (see pics) Hmmm.
I'm wondering if I need to continue adding height to my chimney, or if there is some other strategy? I guess cracking the ash pan door is not the biggest deal in the world, but I don't like disregarding the manual instructions on this. I called the Jotul North America technical office and left a VM, awaiting a call back.
Any ideas or input much appreciated,
