Yes, I am bumping this thread.
To recap, when I was burning stove fulls of wood at or under 7%MC my burn times sucked, i was running at the ragged edge of possibly overheating my cat, and I happened to have a fly ash accumulation temporarily deactivate my combustor.
@BKVP and one of the guys at my local BK dealer spent a bunch of time working with me off forum, thank you both for that. I recognized up front I was outside the operating parameters of the stove and intentionally stopped updating this thread since I
was more or less
alone with my problems.
One thing I did do was open the side curtains on my solar kilns back in October. This prevented the kilns from generating solar gain around my wood stacks and sent my stacks seeking an EMC ~9% instead of the 5%EMC they were seeking with the solar gain from closed curtains.
So I got a couple PMs from a nameless lurker here. It really sounded to me like his wood was too wet. I got two pics in my PM box today. One of them is a MM stuck in a freshly split face of red oak, seasoned 7 years, reading 7.0%MC. The other is a freshly split face of pine reading 11.3%MC.
Rather than PM him back, I am putting this out here where he, and others like him, can maybe find this without cluttering up my PM box.
1. I was blowing a BUNCH of unburnt fuel up the stack when starting from a cold stove getting the cat hot enough to engage. Like half my burn time was used up before I could get the cat engaged. I was literally getting 4-5 hour burns before hot reload when starting with a cold stove. My exhaust plume was epic opaque black on start up. Not just puking fuel, pumping unburnt fuel out the stack, and pumping it hard. Not like an 18 wheeler downshifting, not like a diesel locomotive working up a grade, more like a coal fired battleship at flank speed moving against a strong current.
2. Once hot enough to engage my plume would clean right up, but the cat indicator was soaring up the dial far enough and fast enough to concern me. I am only one data point, but from monitoring the thermometer in the back bedroom of my house furthest from the stove i think the convection deck fans pull a lot of heat off the stove. I doubt they alter the reading on the probe by cooling the coil very much, compared to how much heat is actually being taken off the stove.
What is the number one complaint about the fan decks on BKs? Is it stalled cats, overheated cats, or shortened burn times?
3. I did pick up a legacy cat probe thermometer. It is by Vermont Technologies Inc, from right around the time (early 1980s) when energy efficiency was becoming a thing up here as the pipeline construction ended, the economy crashed and people started caring about energy prices here. We got a ton of lava lamps and orange shag carpet at estate sales too if you are looking for any late 1970s - early 1980s vintage stuff. What I don't have is the install and operation manual for the darn thing. What it has is two conductors in a cloth jacket as the temp pickup. If I can figure out how to install and run it it should be more or less immune to the air flow from the fan deck.
4. What I did in shoulder season, finally, was to just do hot reloads with a half load of wood. It burned quickly, but didn't off gas enough VOC fast enough to push the indicator needle up past the end of the active zone. What I see with wood under 11% MC is every surface of every stick becomes fully engulfed in maybe 15-30 minutes. At 12-16% MC my loads burn across the stove from the coals to the opposite wall, front to back, left to right, whatever. 11% and under, every stick just goes up in smoke all at once. By backing off to a half load I limited the amount of surface area on fire all at once and thereby limited the amount of VOC going into the cat. That kept the needle down in the printed active range, and heck it was shoulder season. I got a insulation envelope, and it works good.
5. By the time I got into 24/7 burning my wood was more moist and the stove has been running pretty well. Now is a good time for to head down to the garage and see where my stacks are. I have 2-3 loads left in my ready rack in the garage, brought it in last Thursday I think, about 5 days ago. The wood I have been burning the last couple months lights pretty darn easy.
5a. Easy enough for visitors to the house to comment on how easily my wife could light the cold stove Christmas Eve. We had a "do" Xmas Eve afternoon and let the house cool off to +75dF from our usual 80-85dF. My wife relit the the stove with "not nearly enough kindling" and "you must be kidding" on a full load of splits. Took right off I am told, I had escaped to go do "man stuff" at the scheduled end of the "thing." I'll go see how dry my current stacks are, BRB, maybe 20 minutes....
