Advantage Plus controls won't stay on
No, got carried away looking at all the stoves and parts. should come up if you search "whitfield pellet stove"
Well ladies and gents, got the new board and the old also sent out for repair. The new board was slightly different than the original. The thermostat wire terminal were lower on the board and hit the frame of the stove when I closed the door. Broke the solder joint and no longer had thermostat control. I repaired the solder joint and made it better than original and all is well. The stove operates like it should now every time. Thank you all so much for the advice and info. Now that I have it working I can concentrate on learning the proper way to operate it.
