Adjusting Carburetor
Mass. Wine Guy
313
Northeastern Massachusetts
When I replaced the spark plug in my Jonsered 535 the tip was very dark brownish. My understanding is that this indicates the saw's fuel mix is running too rich. I know where the high, low and idle adjustment screws are, but I've never adjusted this before. What's the best and simplest method?
Thanks.
Smokinjay,
I run an older (West Germany) 048. I've been cutting at about 6500' and having trouble keeping idle. I rev well and cut great in midrange RPMs and high end RPMs, but when I get out of a cut and decelerate the engine, I will sometimes kill it. I have to feather the throttle to keep the idle. I've adjusted the low everywhere it will go and can't seem to get it to idle. I have the low dialed all the way up and still have trouble keeping an idle. You seem like knowledgable Stihl man, what's the deal with my 048?
P.S., I was told by a Stihl dealer to replace this saw with a new 460 when I was hunting down an aircleaner, but that was about 40 cords ago. Other than the idle, the saw will bury my dad's new 361.
WYO
Wine Guy,
Didn't mean to tread on your thread. I figured we are asking similar questions. Sorry, WYO
WYO said:
Smokinjay,
WYO
I would pay with the hi idle screw listen to the sound wave and make sure the hi idle is set right then you should be able to dial the L screw in a little better. Your h screw will always be differnt each time you cut at that kind of heights so set it everytime you cut.
Mass. Wine Guy said:
How do I get to the spark arrestor to see if it's clogged up? Do I need to remove the muffler or is it just attached to it?
yes remove the front cover and check it.
Well, I removed the muffler but saw no spark arrestor screen at all. I bought the saw in Canada, so maybe it wasn't required there. One less thing to worry about, but it was good experience removing the muffler.
I don't have an idlespeed/throttle stop on the saw...at least not on the external adjustment (outside on cover). I probably have one on the actual carb, but I haven't looked very close. This isn't a problem on the hardwood cuts in Western Nebraska at 3800'.
only need one if you in a very dry forest, how did the piston look?
What ratio are you mixin oil and gas at? What octane gas??
Piston? Uh oh. I didn't look. I can look again. Is the piston inside of the small square opening I see when I remove the muffler?
I mix a 2.6 oz. bottle of 2-cycle oil with 1 gallon of 89 octane gasoline.
I run the highest I can get at 50:1
WG, If the plug is a brown color then this is near ideal setting. A rich mixture would be on the black side.Check to make certain that the air filter is clean. A dirty one could give you a false indication, Ken
Hmm. Maybe I should have left well enough alone, then. Now, after I "adjusted" the carb, the saw doesn't consistently run at full throttle when I have the throttle wide open. Then there are moments where it will suddenly reach the max and sound normal.
Hmmm...
It's always a good idea to count how many half turns the jets are set to so you can get it back into the ballpark should you get too far off.
Are you tuning by ear or with a tack? And you can tune in the cut as well, but you probally dont have it tune right out of the cut.
Dont worry about where the screw is wot until it sound prefect then back of enough to get a slight miss sound. If that doesnt bring it into tune do the same in the cut to almost perfect on a full load.
I tried adjusting my carb, but the saw still seemed slow and underpowered at high throttle under load, so I took it to a local small engine repair guy. If it's better when I get it back I'll pay attention to its sound.
What's the deal on using tachometers? Do you adjust the carb strictly by the numbers? Amick's has a $28 digital tach.
I just had a friend adjust my saw. He said it was running a bit lean. I guess it was set lean from the factory or leaned out as the saw was broken in. It now runs much smoother from startup.
Matt
Newer saws do get a break in period and then they can have the carb set again at a higher speed after some good cutting. Just a suggestion, let a good saw mechanic do it. If you get your saw to lean you can loose the lubricating capacity of the 2 stroke oil and seize saw or loose all your compression from worn rings. Some saws between the cylinder head and the carb area there is slide plate and hole for summer or winter run. Allows for different air temps to enter carb.
Rob
yes, it will get you very close but still good to be able to hear the slight 4 stroke.
Is this shen the engine sounds kind of rough but still runs really well?
yes once it sounds perfect then back off a little its called 4 stoking.
To me, the term "back off" sounds like the wrong direction. You need to go in the other direction and open (richen) it up a little.
