Adding depth to gas fireplace
Jspeed
1
Rochester NY
I would like to remove my hearth from a traditional wood fireplace with gas insert and add depth to the fireplace facade while creating a “floating” fireplace design. Is it possible to build out from the insert? I would like to frame out 10” from the front with cement board and create a design like the following picture. I was wondering if the extension could be lined with something like granite to guide the heat. Basically there would be a bit of a picture frame to the glass of the insert instead of it being right at the front edge. Trying to create something as close as possible to the pictured design. Thank you for any help.
You would have to check the install manual for the specific insert that you will be using. The HeatnGlo inserts that I install can be built out like that as long as ALL of the material used is non combustible (metal studs, cement board). The other concern is that pulling the unit forward will put too much of a bend in the flex liners when they go into the flue.
