I've had a couple of PMs about how I added a Magnehelic gauge to our wood furnace and thought I'd post it here as it's own thread for easy reference.
To connect to the flue pipe, I got a brass fitting that has a 1/4" O.D. tubing compression fitting and a 1/8" male pipe thread (MIP). The hole in the flue pipe is a 3/8" and the pipe thread end of the fitting is simply screwed into it (no tap needed). You could make it extra secure by adding a brass 1/8" FIP lock nut, if you wanted. The flue pipe hole should also be as close to the pipe collar on the furnace as possible and definitely before any baro or key dampers.
1/4" copper tubing runs from the compression side of the fitting to my Magnehelic gauge, which uses an identical fitting to go from the tubing to the 1/8" pipe thread port on the back of the gauge.
If it was a manometer with flexible tubing, I would have terminated the copper tubing with a fitting that had a 1/4" OD compression fitting on one end and a hose barb to fit the manometer tubing on the other.
I made a sheet metal bracket for my gauge to permanently mount it on the furnace.
That's it. Less than $10 in connector parts for either the magnehelic gauge or manometer option. Pictures of my set up are attached.
![Adding a manometer/magnehelic gauge to a flue pipe Adding a manometer/magnehelic gauge to a flue pipe](https://www.hearth.com/talk/data/attachments/268/268734-d2525ae1ab3f78ba346c541b08da3d43.jpg)
![Adding a manometer/magnehelic gauge to a flue pipe Adding a manometer/magnehelic gauge to a flue pipe](https://www.hearth.com/talk/data/attachments/268/268732-73b0f6b5ca068ef4036d7d08af129f96.jpg)
![Adding a manometer/magnehelic gauge to a flue pipe Adding a manometer/magnehelic gauge to a flue pipe](https://www.hearth.com/talk/data/attachments/268/268733-89c27d13a4c656f7908c34c0b6dbc785.jpg)
