I have a Shenandoah AF77 add on furnace. I purchased it nos, (it was made in 1977 but was still new in the crate) it is designed to hook inline with an existing furnace and use the existing furnaces duct work. I do not have an existing furnace so I purchased a furnace blower and wired it up to the thermostatic switch and built my own ductwork. The furnace does not use a thermostat it is basically just a wood stove with a plenum like a hot blast or an englander. It has a 6" pipe and its hooked into a 7x7 clay flue 20' tall. I have a key damper in the pipe and a condar flue guard thermometer above the damper. I try to run the temp around 350 to 400. The thing cranks out heat and easily heats my 2k sq ft ranch and the basement. The problem is I was looking at it today and it already has 6 cracked fire bricks, 3 on each side. Anyone know why this might be happening?
![Add on furnace cracking bricks (long winded) Add on furnace cracking bricks (long winded)](https://www.hearth.com/talk/data/attachments/174/174176-fbb3effbee7563386eb52623a64fd0d0.jpg)
