So I've noticed the very different nature of a low cat burn, where there is little or no flame in the firebox, and of a high burn, where top of the firebox is filled with rolling secondaries. The low-flame burn seems to give higher stove top temps, not surprisingly as the cat is working hard (temps right above the cat over 500f). But the high-flame burn puts out a lot more of a blast of heat, as the front and sides of the stove get much hotter (pushing 650f, while top is only in the 400f range). The sides don't get much over 450-500f when in cat-only burns.
So far, my experience is that to maintain a low burn, the air must be shut down pretty far and pretty early in the burn. I mentioned in the above post that a little boost of air will shift the burn into high gear, but then I can't really shift it back into low... the secondaries seem self-sustaining once they get cranking, even with air setting at zero.
If the fire gets too hot and lively early on in the burn, it seems the rolling secondaries kick in and then stay kicked in... shutting the air all the way back at that point will not take the fire down to a slow, low-flame or no-flame burn of lower heat output. In effect, the option of "dialing down" the stove is lost if not opted for early on in the burn. (This is not a really complaint , BTW... n this high-burn stage, the stove puts out a tremendous amount of heat at relatively low flue temps.)
I suspect this also has something to do with the increased draft seen under colder outdoor conditions, as even with air setting all the way down, when it's cold out I seem to have a harder time getting a real low-output burn with a similar load of wood. Almost as if the stove automatically adjusts to the outdoor temps in its ability to put out heat, where cooler outdoor temps mean more secondary flames in the firebox and less time in cat-only mode.
Wondering if that is the nature of just this stove (or of the way I'm running it) or of these hybrids in general. Seems like maybe a cat-only stove can be dialed down more easily than in a stove where rather than just a cat there is burn-tube technology also at work.
