Well, sort of confused. I've been lurking here and other places trying to learn what I can about wood stoves, but even after searches I still have a few questions-or would like your thoughts on some things.
I have a budget of about 6K for the stove and the chimney. I can increase that if necessary as I want to make sure I do things right the first time rather than skimp a bit-but I would like to be as frugal as I can. I want to cook on the stove a little, but not for elaborate meals or anything like that. Just boil some water, heat some soup and maybe a stew here and there. I have two floors to heat. Probably about 2000 square feet total. I am renovating to open up the entire downstairs-to better heat and I like open space.I think I have narrowed the cast stoves to napoleon, lopi and pacific-they seem to be the preferred from what I have been able to read. Not sure about soap stone though. Placement of the stove isn't a problem as I am renovating I can put it anywhere you suggest.
1. soapstone or cast iron? Of course the soap stone is pretty, but as long as I can watch the flames dance and warm up some coco, I'll be happy. From what I've read, soap is more radiant, but is it enough to warm a space?
2. chimney-masonry or steel. I'm leaning towards steel, I guess the triple insulated? The masonry seem to be less efficient. The stove will be on the first floor so I'm figuring about 30 ft from stove to 3-4 ft over the roof-give or take a bit.
3. Can a chimney be put inside the house? Would a masonry chimney be able to go inside? Just seems like it might be a heating option...I dunno-and I read that somewhere![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
4. to heat the upstairs-I was thinking of a few vents in the ceiling, but I wonder if 1 vent around the stove might be better as to push the air in one direction rather than a few vents and having air get stuck. Will it get stuck? The upstairs will not be open and has a few bedrooms, and such. As it works out, the stove will be under the hallway...so maybe just one vent in that?
I think that is it for now. I live in North East PA. This will hopefully be a primary heat source once I get good at it.
Thanks
Elle
Thanks
Elle
