You mentioned: "So in order to deliver heat to both zones from one furnace/boiler, I think I would need either a shared plenum with a damper system (to preserve the separate heating zones) and basically run air ducts through my access to the crawl space" and you also mentioned storage with a gasifier.
I have to agree with Frozen Canuck. If you truly want to have a gasifier and get the most out of the burn cycle, storage is a must.
That being said, your current boiler would have to be changed out and install air handlers with a coil for the hot water to flow through.
That being said, I would definitely take the time and extra $ to do the insulation upgrades now.
