I have a Regency Hearth heater H2100 woodstove, its got air tubes inside, a thick baffle plate above the tubes and then some insualtion blanket on top of that. i have a temp guage on the outside of the stove pretty much over the center part of it right on top so it would be located essentially ontop of the baffle plate and insulation. how hot can you safely run one of these stoves, the instructions basically say dont let it glow, yeah that helps me out a lot i dont plan on running that hot! i usually run it in the 550 degree range but i dont know if it would run more effiecient and secondary burn better if i ran it hotter???? seems that if its below 500 degrees it doesnt really secondary burn well????
(broken image removed)
