Sounds like a poor draft and the flue gasses are condensing because of the large thermal mass of the masonry chimney. The flue gas temp is just to low to use in a masonry chimney. It's the reason I'm getting rid of mine. That and I could use a little more heat.I'm not convinced your wood is the problem. I (and others here) have burned wood up to 25% moisture content without the problems you describe. Even assuming your wood isn't as dry as you think, your fire shouldn't completely snuff itself out when turned down after a 20 minute burn in with the thermometer on high. This, and the creosote buildup you describe after 3 months of burning on a medium setting, suggests draft problems. Assuming you are keeping the cat in the active range.
I would contact Blaze King. They will be happy to help you.
Even with the proper draft creosote can still be an issue due to the thermal loss into the masonry. Ask me how I know....You may have stronger draft that can help overcome poor wood quality. But his symptoms typically point to wood. But it could be weak draft which is why i asked for more details
Yes I am fully aware of that which is why we only install insulated linersEven with the proper draft creosote can still be an issue due to the thermal loss into the masonry. Ask me how I know....
With a proper drafting chimney, the stove will reach higher operating temps and produce more heat. A quality insulation liner is the prescription with masonry chimneys...especially on exterior walls.Sounds like a poor draft and the flue gasses are condensing because of the large thermal mass of the masonry chimney. The flue gas temp is just to low to use in a masonry chimney. It's the reason I'm getting rid of mine. That and I could use a little more heat.
I honestly think have a BK free standing unit inside a fire place would hurt performance due to heat build up in the fire box making the t-stat think its warmer than what it really is' but check with @BKVP, I could be wrong or over thinking the technology
This fireplace is an interior fireplace right? 6' wide and 4.5' tall but how deep? Will you be able to keep 4" from the back of stove to the brick?
It almost sounds like an alcove installation. The superior performing option is #1 with all vertical, all insulated, 8" liner hooked right to the stove. Will be easy to clean with a sooteater too. A well sealed and insulated block off plate would be important as well as the blower kit.
I would still slide the stove out of the fireplace as far as possible.
I can save you the call...this forum of BK experts are correct. As the masonry absorbs the heat, it may also reflect that heat back towards the rear of the stove. In doing so, the radiant heat could provide false “readings” to the thermostat.Good question, I never would have thought of that. Will call BK tomorrow
