fire starter squares
freebird77
305
Hallstead Pa.
Has anyone used these, as oposed to the gel, and what do you think? I bought a box today and sems a lot cheaper then the gel. Any advice, much appreciated. Doug
I use the Rutland fire starter squares, $11.00 for 144 of them.
I make my own. I can start 3" to 4" wood with no kindling. The ones I make burn for 45 minutes.
I have been using square starters made by Landmann USA. I was looking for gel , but these were all I found on that trip to HD.
They work well for starting the fire, although they stink a bit at first. I can let them burn with a few pellets on top and below the square for about 30 seconds and then close the door. After another minute or so, I start the blower.
I think the plastic wrapper definitely contributes to the clinker, though.
A co-worker uses cedar shavings to get his going. I will try that next.
Super cedars are far the best . :coolgrin:
I cut up old dura flame fire logs. Just slice them with a kitchen knife into about 4x4x1 inch pieces.
(broken link removed to http://www.duraflame.com/aa_products/firelogs01.php)
I've been using the firestarters from Walmart. On comparing the prices, they are the same as the Super Cedars in the 100 pack. If I remember right, they worked quite well with the samples that were given out a few years ago.
Matt
