I've been burning my stove for 1 week now and just tonight learned something on the draft control. Before tonight, I had closed my draft until I felt moderate resistance to rotation and assumed that was "closed". Every time I was frustrated with continued primary and secondary flames and felt the draft control was less than optimal and that I wasn't achieving a high efficiency "cat" burn. Tonight, after getting the stove to min cat engage temp from a cold start, I quickly added 1 6" dia round and a med split of pecan at full draft but without disengaging the cat. I immediately closed the draft and I put a little more force in the closing direction and the draft audibly protested a bit (a metallic "grunch") but rotated a bit further. All flame in the firebox extinguished almost immediately. A couple hours later now and the stove is cruising on the cat at 450 top temp and there has been NO flame in the firebox. Shining a flashlight into the firebox, I can see the round and split I added last and see just some charring on the round (beneath the split) and the split looks unaffected. I believe I've finally got my stove into the highest efficiency mode to date. If your firebox doesn't go black almost immediately, try rotating your draft control a little more towards closed (listen for the metallic "grunch") and see what happens.
As a side note, how long is it taking PH owners to get the stovetop temps to "cat burn range" from a cold start? My experience has been a couple of hours and probably 20-25 lbs of wood (pecan seasoned 2 years) with a wide open draft. Once up to temp, the stove maintains it well,, but it seems it takes a lot of wood at a high burn rate to get there. Way longer than the 10 to 15 minutes WS states in the manual. Any tips on reducing this heat up time are much appreciated.
