Set-up:
Freestanding Stove. Pipe out of the top - 12" to 2- 45's. Then about 18" to wall through the house with a chimney in garage. Built with the standard liner (clay??). Peak of chimney is 32" above peak of roof.
Ok- So I bought this stove used in 2009. Had a VERY annoying whistling from the get-go. Tracked it down to a air hole under the door of it. Put a piece of metal tape over it and it has gone (the whistling). What is that hole for anyhow? I am thinking that the "whistling" must be a clue for the poor draft...
Have always had problems with smoke billowing (sp?) out of the unit when filling. Have made all connections tight with fireplace cement. Used High-Temp silicone on cleanout door on bottom of chimney in the garage to make a air tight seal.
Thought about installing a "fresh air intake" however - where? There is NO obvious area on stove to put one. I am sure I am missing something - but I am not sure where.
ALSO- Brick above baffles or that Vermiculite Board? THere are bricks in mine - but the manual shows the board.
The draft thing is getting REALLY old (lol). Still better than propane - but I am getting frustrated as I have tried several things as a "silent" reader of many forums.
Time to break my silence - thanks in advance for your upcoming replies!
