Hello all, new to the forum (well I've been lurking for a while).
So I live in a manufactured home and recently found a 13-NC and purchased all my pipe from duravent. For the DVL to stovetop adapter the inner crimped section is just about the same exact diameter as the inner section of the stove flue (pointing to it in the uploaded photo). I used some needle nose pliers and spent about 30 min fighting with the thing to try and get it to sit flush inside that inner portion of the stove flue. It just wants to sit on top and not go down in there.
Is that normal? Should I bend more, or cut slits into the crimped section in order to get it to slide down into the stove?
Any help is appreciated.
Thanks.
![6DVL-AD not fitting inside 13-NC stove 6DVL-AD not fitting inside 13-NC stove](https://www.hearth.com/talk/data/attachments/302/302554-80430f2bbd87eac17939e57f7e8df715.jpg)
![6DVL-AD not fitting inside 13-NC stove 6DVL-AD not fitting inside 13-NC stove](https://www.hearth.com/talk/data/attachments/302/302553-cdae1e53a8d33b168e6bf71b2187482a.jpg)
Thanks.
