Efel wood stove now under control
alfio
153
:-) Up date on the efel wood stove .I thing i got this thing under control now , here is what i did , permanent primary air closed , secondary open 1/2 inch , damper open , barometric set to open at 300 degrees and its running at 600 on medium , stack temp at 300 plus or minus 50 degrees , burn time about 6 hrs. thanks guys for all your help . the stove is half full. Ho by the way, thats from worm start this morning the stove top was about 100 degrees 6 am to 11.30 stove was still at 200 degrees and plenty of coal to stack stove.
p.s. here is a picture of the stove running on medium .
  • [Hearth.com] Efel wood stove now under control
What's the smoke coming out of the stack looking like? Hopefully your answer is that there isn't any.
just the heat signature , wands its up temp .
